CEM-5F3C HEATER FAN.SIGNAL TOO HIGH. Condition If the heater fan circuit is short-circuited to voltage supply,the control unit will interpise this as a fault and the diagnostc trouble code cem-5f3c will be set. status.none. Possible source. Signal wire short-circuited to voltage supply.Defective heater fan. kas galetu paiskinti problemos sprendima buciau dekingas!
Lauksiu info gal pas ka taip buvo!
s80 d5 webasto klaida CEM-5F3C
Jegeris
- Pranešimai: 33
- Užsiregistravo: 2014 Spa 04 12:58
- Auto: volvo s-80
- Miestas: Marijampole
