Pats isbandziau su savo 850 T-5 1993 m. veikia 100% Gal kam bus naudinga.
Volvo 850 (1993-1995)
1. There are two diagnostic units(it says A and B on the cover) located adjacent to washer reservoir under the hood. Turn on the ignition and open the module A and insert the flylead into socket 7.
2. Press the button on the diagnostic unit 4 times, briefly but firmly. Then the LED illuminates and stays illuminated, and the system is ready to accept manual code input. A code number for resetting the service reminder light is 1-5-1. To do this, press the test button once and release it And LED illuminates again.
3. Then press 5 times and wait for the LED to illuminate.
4. Press the button once and LED should flashes several times in succession and the reminder should have been reset.
5. Switch off the ignition and replace the flylead in its holder and close the cover.…login to view the rest of this post
Volo 850 1993-1995 serviso lemputes resetinimas
- Aruncikas
- Pranešimai: 25
- Užsiregistravo: 2009 Lie 17 01:21
- Auto: Volvo V70 III
